The mount-control interface
The mount-control interface allows the mounting and unmounting of both transient (non-persistent) and persistent filesystem mount points. The interface does not itself create or maintain mount points, but instead permits the snapped application or service to create and maintain its own.
This interface gives privileged access to the device.
Requires snapd version 2.54+.
Use of nfs requires snapd version 2.67+
Use of cifs requires snapd version 2.68+
Developer details
Auto-connect: no
Super-privileged: yes
Attributes:
  • persistent (plug): defines whether the mount can be persistent or not.
    Either true or false. Defaults to false.
  • type (plug): lists one or more acceptable filesystems for this mount.
    Example: [ext2, ext3, ext4]
  • what (plug): absolute path of what to mount using a matching wildcard.
    Example: /dev/sd*
  • where (plug): either an absolute destination path for the mount, or a starting reference to $SNAP_COMMON or $SNAP_DATA optionally followed by a path. Wildcards are also supported.
    Example: /media/$USER/**
  • options (plug, required): a list of one or more permitted options.
    Example: [rw, sync]
  • namespace (plug): either snap, for locations within the snap, host, for locations outside the snap, or auto to set the namespace according to the where pattern. Defaults to auto.
See AppArmor globbing syntax for details on how the pattern matching and wildcards work.
It’s the responsibility of the snapped application or service to create and maintain a mount point, using either of the following:
The snapctl mount command is the only option for creating a persistent mount point via its --persistent mount option.
Accepted filesystems
Most filesystem types which are supported by the host system are allowed by this interface, with a few exceptions.
The following filesystems are not accepted:
bpf, cgroup, cgroup2, debugfs, devpts, encryptfs, hugetlbfs, overlayfs, proc, securityfs, sysfs, and tracefs.
While other filesystems are accepted, the following filesystems are supported along with their respective filesystem-specific mount options (more on mount options below):
adfs, affs, aufs, autofs, btrfs, cifs, ext2, ext3, ext4, fat, functionfs, fuse, hfs, hpfs, iso9660, jfs, msdos, nfs, nfs4, ntfs, ntfs-3g, lowntfs-3g, ramfs, reiserfs, squashfs, tmpfs, ubifs, udf, ufs, umsdos, usbfs, vfat, xfs, and zfs.
Note: If only tmpfs is specified, what must be none. The tmpfs type cannot be listed with any other types in a single mount entry.
Note: When using nfs or cifs types, attribute what must be left out from the mount entry in plug attributes. Since neither of those types can be listed with any other fs types in a the same entry it is recommended do add a separate entry for NFS or CIFS.
Permitted mount options
The following filesystem-independent mount options are permitted:
async, atime, auto, bind, defaults, diratime, dirsync, iversion, lazytime, noatime, noauto, nodev, nodiratime, noexec, nofail, nogroup, noiversion, nolazytime, nomand, noowner, norelatime, nosuid, nostrictatime, nouser, nousers, relatime, ro, rw, strictatime, and sync.
Note: Option bind is only allowed when no filesystem is specified.
Filesystem-specific mount options are also permitted, so long as each is supported by every filesystem listed in the corresponding type section. The mount options supported by a given filesystem can usually be found in its respective manpage or in the mount manpage. The complete list of supported filesystem-specific mount options for each filesystem type is included in the source code for this interface.
Code examples
plugs:
 mntctl:
  interface: mount-control
  mount:
  - what: /dev/sd*
    where: /media/**
    type: [ext2, ext3, ext4]
    options: [rw, sync, user_xattr]
  - what: /usr/**
    where: $SNAP_COMMON/**
    options: [bind]
  - what: /dev/sda{0,1}
    options: [ro]
  - what: /dev/sdb[0-1]
    where: $SNAP_COMMON/{foo,other,**}
    options: [sync]
  - where: /media/**
    type: [nfs]
    options: [rw]
  - where: /media/**
    type: [cifs]
    options: [rw]
apps:
 app:
  plugs: [mntctl]
The test code can be found in the snapd repository: https://github.com/snapcore/snapd/blob/master/interfaces/builtin/mount_control_test.go
The source code for the interface is in the snapd repository: https://github.com/snapcore/snapd/blob/master/interfaces/builtin/mount_control.go
Last updated 3 months ago.
